[GRASS-dev] [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
trac at osgeo.org
Mon Oct 15 14:04:18 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: location wizard, g.proj | Platform: All
Cpu: All |
Comment(by neteler):
Ticket #1748 contains a patch for g.proj with various backports of fixes
by Paul Kelly
which lead to these results:
GRASS 6.4.3svn (nc_spm_08):~ > g.proj proj4='+proj=longlat +datum=nzgd49'
datumtrans=-1 -d
GRASS datum code: nzgd49
WKT Name: New_Zealand_Geodetic_Datum_1949
Datum transformation parameters (PROJ.4 format):
towgs84=59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993
GRASS 6.4.3svn (nc_spm_08):~ > g.proj epsg=27200 datumtrans=-1 -d
GRASS 6.4.3svn (nc_spm_08):~ > g.proj -d proj4='+proj=utm +datum=eur50'
datum=eur50
WARNING: Datum <unknown> not recognised by GRASS and no parameters found
Datum set to <eur50>
Ellipsoid set to <international>
GRASS datum code: eur50
WKT Name: European_Datum_1950
Datum parameters not present; default for eur50 is:
towgs84=-87.000,-98.000,-121.000
Ticket URL: <http://trac.osgeo.org/grass/ticket/1452#comment:29>
