[GRASS-dev] images2gif.py in grass
Martin Landa landa.martin at gmail.com
Tue Oct 16 06:55:30 PDT 2012
2012/10/16 Sören Gebbert <soerengebbert at googlemail.com>:
> i would prefer to convert the images in a "real" video format to avoid
> the limitations of GIF.
> Maybe you could try to use PyMedia[1],[2] (well, its pretty old) or
> utilize mencoder[3] to create the videos?
creating video output, eg. using `mencoder` could be added later
(another dependency, will not work on Windows). I would suggest to
start with something which will work on all supported platforms
without any extra dependency (which seems to be `images2gif`).
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
