[GRASS-dev] v.net.allpairs seems broken
Moritz Lennert
mlennert at club.worldonline.be
Wed Oct 17 01:52:29 PDT 2012
On 16/10/12 15:34, Michael Barton wrote:
> Fixing this makes the module usable. The flaw is near to a bug.
Well, you can use the module as-is. You just have to make sure that
nodes and arcs have different cat values, e.g.:
#check cat values in arcs layer (streets_wake here):
v.category streets_waks op=report
#take the existing cat values of the points in schools_wake and add
50000 (because the cat values in streets_wake go up to just under 50000)
v.category schools_wake out=schools op=sum cat=50000
#now link the nodes with their new categories to the arcs
v.net streets_wake points=schools op=connect thresh=200 out=network
nlayer=1
#then launch your analysis indicating the cat values of the points
v.net.allpairs network cats=50000-50167 out=allpairs
So it is possible, but should be documented.
I do agree though that it's a real PINA compared to the simple two-layer
system in other modules.
Moritz
> +1
> Michael ____________________ C. Michael Barton Director, Center for
> Social Dynamics& Complexity Professor of Anthropology, School of
> Human Evolution& Social Change Arizona State University
> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC) fax:
> 480-965-7671 (SHESC), 480-727-0709 (CSDC) www:
> http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Oct 16, 2012, at 4:12 AM, Moritz
> Lennert<mlennert at club.worldonline.be> wrote:
>> Or we decide to break the rule to not change options and backport
>> the alayer/nlayer patches from grass 7 to grass 6, as it is such an
>> obvious design flaw compared to the general logic of the v.net.*
>> modules.
>> What do you think ?
