[GRASS-dev] [GRASS GIS] #1759: Selecting maps in dropdown menu: slider to move up/down maps does not work
trac at osgeo.org
Wed Oct 17 07:03:55 PDT 2012
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-trunk
Keywords: map selection | Platform: Linux
Cpu: x86-64 |
Comment(by annakrat):
I tried wxpython demo with Ubuntu 12.04 and the problems are there too.
The only thing I can recommend you is to disable the overlay scrollbar
feature as described [http://askubuntu.com/questions/36448/is-there-a-way-
to-blacklist-an-individual-application-from-using-overlay-scrollb here],
then it is working correctly.
I have no idea why the arrows don't work at all. This widget is full of
bugs. Maybe we should use a different one, there is
[http://wxpython.org/docs/api/wx.lib.combotreebox-module.html
ComboTreeBox] which seems to have the same functionality and it is working
properly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1759#comment:2>
