[GRASS-dev] dateutil dependency killing GRASS 7
Glynn Clements
glynn at gclements.plus.com
Wed Oct 17 13:20:59 PDT 2012
Moritz Lennert wrote:
> > sorry to introduce something painful as a python-dateutil dependency.
> > My fault. I should have discussed this on the list indeed.
> > I have completely removed the dateutil dependency from the temporal
> > GIS in r53435. For now
> > only two types of calendar time stings are supported for parsing.
> Do you really have to remove it completely ? Can't you check for its
> presence and if not present fall back on the basic date version ? And
> put a hint in the manuals about its installation being strongly
> recommended ?
Then it would become a /de facto/ mandatory dependency.
