[GRASS-dev] [GRASS GIS] #1736: wxNVIZ volume display crashes Mac
trac at osgeo.org
Thu Oct 18 16:17:50 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by martinl):
Replying to [comment:2 cmbarton]:
> This is something that did work within the past year and now is broken.
Not sure why.
> But it effectively makes all the volume commands useless if you cannot
display the result. I was trying to test some alternative files with
Helena to debug this, but we found out that r3.in.ascii is also broken
now. I don't know if she filed a report or not. I'd copy her here, but
apparently there is no longer a way to add someone to this ticket.
can you provided more detailed info, at least in which sense `r3.in.ascii`
is broken? Note that ticket is marked as blocker. We need to move on.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1736#comment:3>
