[GRASS-dev] [GRASS GIS] #1692: calling a script within a script failing on Windows XP
trac at osgeo.org
Sun Oct 21 01:18:12 PDT 2012
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: blocker | Milestone: 6.4.3
Component: Shell Scripts | Version: 6.4.2
Keywords: v.random.cover, wingrass, shell scripts | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:15 martinl]:
> Replying to [comment:9 hellik]:
> please try next build (G65), I hope that r53512 will be better.
System Info
GRASS version: 6.5.svn
GRASS SVN Revision: 53516
GIS Library Revision: 50936 (2012-02-25)
GDAL/OGR: GDAL 1.9.2, released 2012/10/08
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
v.random.cover --verbose cover=fields at PERMANENT cat=63
output=random_NP_cover n=500 raster=landcover.30m at PERMANENT
WARNING: Layer 1 - no table
Created <random_NP_cover> with 500 random points
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected $end processing
in statement:
Error in db_open_select_cursor()
WARNING: 39 points outside current region were skipped
Raster values from <landcover.30m at PERMANENT> uploaded to
column <sampled>
(Sun Oct 21 10:12:23 2012) Command finished (6 sec)
it seems the 'command not found'-issue is solved, more testing welcomed.
thanks
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1692#comment:16>
