[GRASS-dev] [GRASS GIS] #1692: calling a script within a script failing on Windows XP
trac at osgeo.org
Mon Oct 22 13:07:32 PDT 2012
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: blocker | Milestone: 6.4.3
Component: Shell Scripts | Version: 6.4.2
Keywords: v.random.cover, wingrass, shell scripts | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:18 martinl]:
> Replying to [comment:17 martinl]:
> > backported to `relbr64` in r53519
> with the last winGRASS build, it seems to work. Testing welcomed...
this ticket was about shell-scripts; maybe following it's worth for an
extra ticket?:
there are some very nice python-based-script-addons for grass6.x, like the
inter-dependent r.basin-, r.ipso-, r.wf-scripts (and others).
the pyhton addon-sscripts (r.basin.py, etc.) are stored in
C:\Users\XXXX\AppData\Roaming\GRASS6\addons, whereas the related bat-files
(r.basin.py.bat) are in C:\Users\XXXX\AppData\Roaming\GRASS6\addons\bin.
the content of the bat-files are e.g.
@"%GRASS_SH%" "%GISBASE%/scripts/r.basin.py" %*
in windows ''#!/usr/bin/env python'' isn't recognized, so ''"%GRASS_SH%"''
should be changed to ''"%GRASS_PYTHON%"''
but changing this manually, r.basin calling r.ipso/r.wf isn't really
working.
AFAIK python addons-scripts aren't at the moment ''officially'' supported
in grass6.x (working out of the box in linux, but not in windows),
although it would be nice if such peculiar scripts would also be available
in windows.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1692#comment:22>
