[GRASS-dev] [GRASS GIS] #1554: wxGUI Cartographic Composer: preview broken on Windows
trac at osgeo.org
Thu Oct 25 01:54:03 PDT 2012
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: unspecified
Keywords: cartographic composer, psmap, wingrass | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:6 martinl]:
> Replying to [comment:5 annakrat]:
> > * Ghostscript is missing (not in OSGeo4W framework)
> just a quick test, I have added Ghostscript [1] then I have tried to
produced PS using wxGUI Cartographic Composer, the file has been created.
But if I try to open it using e.g. Gimp, it fails.
I don't understand much. You tried the preview or exporting PS file? The
creation of the ps file is not related to this ticket, the reading of the
ps file by PIL is the problem. When GIMP on Windows is not able to read
it, it's a problem of ps.map module.
The 'unix only' and '>/dev/null 2>/dev/null' in the ghostscript command
must be a serious problem for Windows or not?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1554#comment:8>
