[GRASS-dev] v.transform dysfunctional in 6.4.3.svn
Markus Metz markus.metz.giswork at gmail.com
Thu Oct 25 08:23:09 PDT 2012
On Thu, Oct 25, 2012 at 12:06 PM, Benjamin Ducke <benducke at fastmail.fm> wrote:
> Dear Devs,
> it seems that some recent additions to v.transform have broken
> the module. There are several places in which read or write
> operations to addresses that have not been malloc'd lead to
> crashes.
> The problems all seem to be related to the new option "table=".
> It is unclear to me what this option is intended for. Is it
> an input or an output option? Maybe some information should
> be added to the HTML manual page.
This table option is a bit strange. Looking at the code, it is not
clear which column is used as key column to select the appropriate
transformation parameters for a given point, probably a column named
"cat". Furthermore, there are no options to define database and
driver. In GRASS 7, I have removed the table option, the table is here
selected through the layer option, which is also used to select the
appropriate category for a given point, also in GRASS 6.
I have changed the behaviour of v.transform in r53553/4 such that the
table option can be safely ignored. Individual transformation
parameters stored in an attribute table can be used with the 'layer'
and 'columns' option. In theory the table option is still recognized.
Is this OK?
Markus M
> Anyhow, without the "table=" option set, v.transform crashes
> due to this block of code on line 166 of trans_digit.c:
> if (field > 0) {
>         db_close_database_shutdown_driver(driver);
>         G_free((void *)trans_params);
> The problem here is that "driver" never gets malloc'd,
> unless the "table=" option is given (look at lines
> 53 and following in trans_digit.c).
> With the "table=" option given, there are still illegal
> write operations. Valgrind points to lines 88, 126 and
> 136 of trans_digit.c as culprits. These will make
> v.transform crash or not -- depending on your luck.
> Cheers,
> Ben
> Benjamin Ducke
> {*} Geospatial Consultant
> {*} GIS Developer
>   benducke AT fastmail.fm
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
