[GRASS-dev] composer preview
Michael Barton Michael.Barton at asu.edu
Thu Oct 25 15:23:23 PDT 2012
So that was easier to test than I thought. I had not reinstalled X11 on one of my computers since updating to OS X 10.8. Even with PIL installed, here is what happens:
1. When I click the preview button, I get the following screen.
If I click "continue" it takes me to the XQuartz project site to install XQuartz. If I click cancel, I get the following error:
So this is a PIL/Ghostscript/X11 issue. Note that Ghostscript IS installed on my Mac by default.
After installing a XQuartz, the composer preview works. This is not a huge problem on the Mac then, but it seems like people should not need to install X11 solely for converting pdf2png. No other way?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Oct 25, 2012, at 1:13 PM, Anna Kratochvílová <kratochanna at gmail.com>
 wrote:
> On Thu, Oct 25, 2012 at 6:49 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> Anna,
>> I am happy to test. But composer preview has worked for me in the past once I installed PIL. I do have Ghostscript. I installed it manually long ago, but I'm pretty sure that it comes with the Mac OS these days.
> I thougt the preview was not working for you because of the ticket
> [1]. If it is working there is probably nothing to test.
> Thanks anyway,
> Anna
> [1] http://trac.osgeo.org/grass/ticket/1715
>> Michael
>> C. Michael Barton
>> On Oct 25, 2012, at 12:11 AM, Anna Kratochvílová <kratochanna at gmail.com>
>> wrote:
>>> Hi Michael,
>>> could you do a test for me with the cartographic composer? The preview
>>> can be broken for several reasons [1]. Could you check that you have
>>> Ghostscript installed? Then, if you have it, try if it is on the PATH.
>>> If not, could you put it on the PATH? Then it could work on Mac. But
>>> there is probably no chance to make it work on Windows.
>>> Thanks,
>>> Anna
>>> [1] http://trac.osgeo.org/grass/ticket/1554#comment:5
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121025/d5cf3d5f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121025/d5cf3d5f/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121025/d5cf3d5f/attachment-0003.png>
