[GRASS-dev] [GRASS GIS] #1736: wxNVIZ volume display crashes Mac
trac at osgeo.org
Tue Oct 30 12:24:57 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by cmbarton):
I tried setting debug=5 and crashing wxNVIZ with the most recent build
from trunk. To get the crash, I used Helena's test DEM and volume. I set
the region to match the volume and loaded both DEM and volume into the
layer manager. Then I displayed them with wxNVIZ. I switched to the volume
window under the data tab and added an isosurface. No crash yet. Then I
tried to change the level displayed by the isosurface from the default
(minimum value) to 10. This is where the crash happens. Here is the debug
output for that action. Hopefully it can identify what is happening
D3/5: GVL_vol_exists
D5/5: gvl_get_vol():
D5/5: id=81721
D3/5: GVL_isosurf_num_isosurfs
D5/5: id=81721
D5/5: id=81721
D5/5: id=81721
D3/5: GVL_isosurf_set_att_const() id=81721 isosurf_id=0 att=1
const=10.000000
D5/5: gvl_isosurf_get_isosurf(): id=81721 isosurf=0
D5/5: id=81721
D5/5: gvl_isosurf_set_att_const(): att=1, const=10.000000
D5/5: gvl_isosurf_set_att_src
D5/5: isosurf_get_att_src
D5/5: gvl_isosurf_set_att_changed
D3/5: GS_clear
D3/5: GS_ready_draw
D3/5: GS_get_zrange(): min=-0.09 max=22.33
D3/5: GS_get_aspect(): left=0, right=797, top=545, bottom=0
D3/5: GS_draw_wire(): id=110658
D5/5: gs_get_surf():
D5/5: id=110658
D3/5: gsd_wire_surf(): id=110658
D5/5: gs_get_att_src(): id=110658, desc=1
D5/5: gs_get_att_typbuff(): id=110658 desc=1 to_write=0
D5/5: gs_get_att_typbuff(): id=110658 desc=2 to_write=0
D5/5: gs_update_curmask(): id=110658
D3/5: GS_done_draw
D3/5: GS_ready_draw
D3/5: GS_clear
D5/5: id=110658
D3/5: GS_get_zextents(): id=110658
D3/5: GS_draw_surf(): id=110658
D5/5: id=110658
D5/5: gsd_surf(): id=110658
D3/5: GS_ready_draw
D3/5: GS_done_draw
D3/5: GS_ready_draw
D3/5: GS_done_draw
D3/5: GS_ready_draw
D5/5: id=81721
D5/5: gvld_vol(): id=81721
D5/5: gvl_slices_calc(): id=81721
D5/5: color buf = [0% yellow]
D5/5: color buf = [20% green]
D5/5: color buf = [40% cyan]
D5/5: color buf = [60% blue]
D5/5: color buf = [80% magenta]
D5/5: color buf = [100% red]
D5/5: gvld_slices
D3/5: gvl_write_char(): reallocate memory for pos : 0 to : 1000000 B
pythonw2.6(12150,0xacbe1a28) malloc: *** error for object 0xdea2000:
pointer being realloc'd was not allocated
*** set a breakpoint in malloc_error_break to debug
Ticket URL: <http://trac.osgeo.org/grass/ticket/1736#comment:10>
