[GRASS-dev] [GRASS GIS] #1776: Python error by startup
trac at osgeo.org
Wed Oct 31 07:13:47 PDT 2012
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
Comment(by pvanbosgeo):
When starting R from within GRASS, I am getting the following lines, which
do not show when started R normally (not from within GRASS) from the
command line:
During startup - Warning messages:
1: Setting LC_CTYPE failed, using "C"
2: Setting LC_COLLATE failed, using "C"
3: Setting LC_TIME failed, using "C"
4: Setting LC_MESSAGES failed, using "C"
5: Setting LC_PAPER failed, using "C"
6: Setting LC_PAPER failed, using "C"
7: Setting LC_MEASUREMENT failed, using "C"
I am guessing this has the same underlying problem?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1776#comment:4>
