[GRASS-dev] v.net.allpairs seems broken
Markus Metz
markus.metz.giswork at gmail.com
Wed Oct 31 14:29:26 PDT 2012
On Mon, Oct 15, 2012 at 5:11 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Mon, Oct 15, 2012 at 4:34 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
>> One thing that is confusing is that the text for both entries alayer and
>> nlayer shows up as "Layer number or name" instead of the text that is
>> actually in the description field "Arc layer" and "Node layer". Any idea why
>> this is so?
> The label for the standard option G_OPT_V_FIELD is by default set to "Layer
> number or name", and the label, if set, is used as text next to the option
> key. Having "Arc layer" or "Node layer" next to the key can be easily done
> be making "Arc layer" or "Node layer" option labels, which should then be
> done for all v.net.* modules.
Done for trunk in r53630.
Markus M
