[GRASS-dev] r.modis in GRASS 7 trunk
Yann Chemin yann.chemin at gmail.com
Wed Oct 31 20:03:42 PDT 2012
Hi Glynn,
I would like to have that kind of Makefile,
so I can build all grass add-ons related to GRASS 7 SVN without changing
anything in the structure of the SVN
Could anyone help us to get somewhere near to that effect, even if we would
need a configure option like --build-addons-dir=../grass-addons/grass7 that
would be neat.
Thank you,
Yann
On 1 November 2012 03:03, Glynn Clements <glynn at gclements.plus.com> wrote:
> Moritz Lennert wrote:
> > > I suggest that modules should not simply be moved from addons to
> > > trunk, but that a developer has a close look at a module including
> > > testing before moving it to trunk.
> > +1, but I see Martin's point about lack of dev power. So the trade-off
> > has to be between quality of code and value added of having a
> > functionality in trunk even if the code is not perfect.
> Relegating something to add-ons is a reliable way to reduce the amount
> of developer oversight it gets. E.g. currently you can't just "make"
> the add-ons/grass7 directory (it lacks a Makefile), so most developers
> won't even try to compile it. If the modules were in trunk, developers
> may notice errors or warnings as part of the normal build process.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Yann Chemin
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121101/6325fb78/attachment.html>
