[GRASS-dev] compiling relbrand64 fails on windows
Helmut Kudrnovsky
hellik at web.de
Sun Sep 2 13:54:11 PDT 2012
>The "o" indicates that SHLIB_LD is empty, while the missing ".dll"
>suffix indicates that SHLIB_SUFFIX is empty.
>I have no idea why it would only affect these specific libraries; or
>are you doing an incremental build (no "make clean")?
completely fresh svn-checkout and then following the instructions in
http://trac.osgeo.org/grass/wiki/CompileOnWindows#CompilingandInstallingGRASS6.4.x
by using
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows/osgeo4w/package.sh
maybe an (msys)/mingw/gcc-issue?
build environment based upon osgeo4w
(http://trac.osgeo.org/osgeo4w/ ,
http://download.osgeo.org/osgeo4w/versions.html )
$ gcc --version
gcc.exe (GCC) 3.4.5 (mingw-vista special r3)
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/compiling-relbrand64-fails-on-windows-tp4999094p4999276.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
