[GRASS-dev] how to represent an argument as a variable in a grass python command
Michael Barton
Michael.Barton at asu.edu
Sun Sep 2 14:25:33 PDT 2012
Thanks much!!!
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 2, 2012, at 2:22 PM, Anna Kratochvílová <kratochanna at gmail.com>
wrote:
> On Sun, Sep 2, 2012 at 11:04 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> I'm trying to do a script that calls g.copy
>> I want the user to be able to select which type of data to copy. So instead
>> of specifying:
>> grass.run_command('g.copy', rast='%s,%s' % (input, output))
>> I'd like to something equivalent to:
>> grass.run_command('g.copy', '%s=%s,%s' % (datatype, input, output))
>> where datatype is the form of grass data to copy (eg, rast, vect, etc)
>> The way I'd like to do this doesn't work. So what is the correct syntax
>> here?
> Create a dictionary first:
> dataType = 'rast'
> params = {dataType: '%s,%s' % (input, output)}
> grass.run_command('g.copy', **params)
> Maybe someone comes up with something better but this works.
> Anna
>> Thanks
>> Michael
>> C. Michael Barton
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
