[GRASS-dev] [GRASS GIS] #1717: layer remove does not work on multiple selections
Paulo van Breugel p.vanbreugel at gmail.com
Mon Sep 3 01:58:49 PDT 2012
I was mostly concerned with the 'remove' function. But I just tried the
'Set computational region from selected maps' and it doesn't work for me
either. It sets the region for the first map of the selected ones.
But I am running GRASS GIS 7 (on Ubuntu 12.04), so was this not changed
for GRASS 7?
Cheers
Paulo
>   Reporter:  cmbarton                       |       Owner:  grass-dev@…
>       Type:  enhancement                    |      Status:  new
>   Priority:  normal                         |   Milestone:  6.4.4
> Component:  wxGUI                          |     Version:  svn-releasebranch64
>   Keywords:  layer manager, multiselection  |    Platform:  Unspecified
>        Cpu:  Unspecified                    |
> Comment(by annakrat):
>   Are we really talking about the same thing? For example when I select 2
>   layers and choose 'Set computational region from selected maps' this
>   command is executed (copied from command output):
>   g.region rast=elevation at PERMANENT,aspect at PERMANENT -p
>   So this is ok. Is it possible that it's not working on Mac? I agree that
>   it is not possible to move them by dragging.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120903/e9868f19/attachment.html>
