[GRASS-dev] [GRASS GIS] #1720: r.viewshed doesn't compile in GRASS 7
trac at osgeo.org
Mon Sep 3 14:01:39 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Keywords: r.viewshed | Platform: Unspecified
Cpu: Unspecified |
i don't know exactly when this started, but it is recent.
Last login: Mon Sep 3 13:55:06 on ttys000
Michaels-MacBook-Air:~ cmbarton$ cd
/Users/Shared/grass_dev/grass70_dev/raster/r.viewshed
Michaels-MacBook-Air:r.viewshed cmbarton$ make
c++ -arch i386 -isysroot /Developer/SDKs/MacOSX10.6.sdk
-I/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-
darwin12.1.0/include -I/Users/Shared/grass_dev/grass70_dev/dist.x86_64
-apple-darwin12.1.0/include -D_FILE_OFFSET_BITS=64 -DUSER=\"cmbarton\"
-Wno-sign-compare -DPACKAGE=\""grassmods"\"
-apple-darwin12.1.0/include -o OBJ.x86_64-apple-darwin12.1.0/distribute.o
-c distribute.cpp
In file included from distribute.cpp:52:
In file included from /Users/Shared/grass_dev/grass70_dev/dist.x86_64
-apple-darwin12.1.0/include/grass/iostream/ami.h:56:
-apple-darwin12.1.0/include/grass/iostream/empq_impl.h:43:
-apple-darwin12.1.0/include/grass/iostream/empq.h:51:
darwin12.1.0/include/grass/iostream/embuffer.h:1140:56: error:
default arguments cannot be added to an out-of-line definition of a
member
of a class template
long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos=0) {
-apple-darwin12.1.0/include/grass/iostream/empq.h:53:
darwin12.1.0/include/grass/iostream/minmaxheap.h:512:7: error:
reference to non-static member function must be called; did you mean
to
call it with no arguments?
if (size) {
distribute.cpp:89:15: warning: format string is not a string literal
(potentially insecure) [-Wformat-security]
G_message(_("Start distributed sweeping."));
darwin12.1.0/include/grass/glocale.h:10:16: note:
expanded from macro '_'
#define _(str) G_gettext(PACKAGE,(str))
distribute.cpp:149:15: warning: format string is not a string literal
G_message(_("Distribution sweeping done."));
2 warnings and 2 errors generated.
make: *** [OBJ.x86_64-apple-darwin12.1.0/distribute.o] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720>
