[GRASS-dev] Fwd: r.viewshed does not compile in GRASS 7 either
Michael Barton
Michael.Barton at asu.edu
Mon Sep 3 14:15:05 PDT 2012
r.viewshed and r.terraflow problems in compiling seem to have the same cause
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Begin forwarded message:
From: William Kyngesburye <kyngchaos at kyngchaos.com<mailto:kyngchaos at kyngchaos.com>>
Subject: Re: r.viewshed does not compile in GRASS 7 either
Date: September 3, 2012 2:10:02 PM MST
To: Michael Barton <michael.barton at asu.edu<mailto:michael.barton at asu.edu>>
same error as the r.terraflow error you found a few days ago ;)
On Sep 3, 2012, at 4:02 PM, Michael Barton wrote:
So r.viewshed doesn't compile either now (probably didn't a few days ago, but I didn't see it because of all the temporal module errors. I just did a ticket.
Michael
Here is the error:
Last login: Mon Sep 3 13:55:06 on ttys000
Michaels-MacBook-Air:~ cmbarton$ cd /Users/Shared/grass_dev/grass70_dev/raster/r.viewshed
Michaels-MacBook-Air:r.viewshed cmbarton$ make
c++ -arch i386 -isysroot /Developer/SDKs/MacOSX10.6.sdk -I/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include -I/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include -D_FILE_OFFSET_BITS=64 -DUSER=\"cmbarton\" -Wno-sign-compare -DPACKAGE=\""grassmods"\" -I/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include -I/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include -o OBJ.x86_64-apple-darwin12.1.0/distribute.o -c distribute.cpp
In file included from distribute.cpp:52:
In file included from /Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/ami.h:56:
In file included from /Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/empq_impl.h:43:
In file included from /Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/empq.h:51:
/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/embuffer.h:1140:56: error:
default arguments cannot be added to an out-of-line definition of a member
of a class template
long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos=0) {
In file included from /Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/empq.h:53:
/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/minmaxheap.h:512:7: error:
reference to non-static member function must be called; did you mean to
call it with no arguments?
if (size) {
distribute.cpp:89:15: warning: format string is not a string literal
(potentially insecure) [-Wformat-security]
G_message(_("Start distributed sweeping."));
/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.1.0/include/grass/glocale.h:10:16: note:
expanded from macro '_'
#define _(str) G_gettext(PACKAGE,(str))
distribute.cpp:149:15: warning: format string is not a string literal
G_message(_("Distribution sweeping done."));
2 warnings and 2 errors generated.
make: *** [OBJ.x86_64-apple-darwin12.1.0/distribute.o] Error 1
C. Michael Barton
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120903/ee9969c6/attachment-0001.html>
