[GRASS-dev] GRASS6.4.3svn d.rast -o, region in wxnviz
Anna Kratochvílová
kratochanna at gmail.com
Wed Sep 5 02:55:09 PDT 2012
On Wed, Sep 5, 2012 at 6:01 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> So far everything seems to be running quite well in 6.4.3, except for some cosmetics
> that I will collect and report together and the following two issues (probably not quite bugs but
> a confusing behavior):
> wxnviz: if a new region is set, zoom to computational region adjusts the display and nviz respects the new region, but wxnviz does not,
> I had to quit GRASS with new region to get wxnviz respect it.
In grass 7 this works but not in grass 6.x because when I backported
wxNviz I wasn't able to backport also the part related to resetting
the region (G_unset_region is needed). This would need some changes in
gis library which I don't want to do, the differences between 6.x and
7 are quite large.
> d.rast -o landuse96_28m cat=1,2
> run in command console is interpreted as follows:
> Command 'd.rast -l -a -n -d -u -s -e -9 -6 -_ -2 -8 -m
> map=-o cat=1,2' failed
> Details: Sorry, <l> is not a valid flag
> Sorry, <a> is not a valid flag
> Sorry, <n> is not a valid flag
> Sorry, <d> is not a valid flag
> Sorry, <u> is not a valid flag
> Sorry, <s> is not a valid flag
> Sorry, <e> is not a valid flag
> Sorry, <9> is not a valid flag
> Sorry, <6> is not a valid flag
> Sorry, <_> is not a valid flag
> Sorry, <2> is not a valid flag
> Sorry, <8> is not a valid flag
> Sorry, <m> is not a valid flag
> d.rast landuse96_28m cat=1,2 -o works fine.
I tried to fix it so it should work now. I hope I didn't break
something else, this is quite difficult to test.
> add volume still does not open dialog
Maybe someone else (who is more familiar with PATH and Makefiles) could help?
Anna
> I am running Michaels Mac binary,
> Helena
> Helena Mitasova
> Associate Professor
> Department of Marine, Earth, and Atmospheric Sciences
> 2800 Faucette Drive, Rm. 1125 Jordan Hall
> North Carolina State University
> Raleigh, NC 27695-8208
> hmitaso at ncsu.edu
> "All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
