[GRASS-dev] [GRASS GIS] #1719: GRASS 7 Monitor command line support
trac at osgeo.org
Wed Sep 5 04:45:53 PDT 2012
Reporter: annalisapg | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: d.mon | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
So let's start brainstorming about rendering.
Currently used options:
* wxGUI renders to uncompressed PPM and uses g.pnmcomp
* Glynn suggested that composition should be done by wxGUI
([http://lists.osgeo.org/pipermail/grass-dev/2012-August/059188.html
link])
* can PIL be used? (currently only Cartographic Composer preview depends
on it)
* wxWidgets xganim reads a raster file directly and stores data in
wxImage
* it is fast in C++ but to do the same in Python you have to use some
numpy magic to make it at least comparably fast (Anna can tell more)
* G_fatal_error() and exit() are still here
* in order to provide full drawing capabilities code from d.* modules
have to be moved to library
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:11>
