[GRASS-dev] [GRASS GIS] #854: g.extension does not work on a Mac (probably not on Windows either
trac at osgeo.org
Fri Sep 7 04:52:17 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Installation | Version: svn-releasebranch64
Keywords: g.extension, addons | Platform: All
Cpu: All |
Comment(by neteler):
Replying to [comment:20 neteler]:
> Here a test on Ubuntu with GRASS 7, via the wxGUI extension manager:
> (Fri Sep 7 04:01:24 2012)
> g.extension extension=r.houghtransform svnurl=http://svn.osgeo.org/grass
/grass-addons/grass7
> linesegmentsextractor.cpp:136:21: warning: conversion to
> ‘float’ from ‘double’ may alter its value
> [-Wconversion]
> /bin/sh: 1: /media/Proyectos/GISData_grass/South_america_cli
> mate_lonlat/Ortiz_j/.tmp/cito/4172.0/r.houghtransform/bin/r.
> houghtransform: Permission denied
> make: *** [r.houghtransform.tmp.html] Error 1
> ERROR: Compilation failed, sorry. Please check above error messages.
> (Fri Sep 7 04:01:33 2012) Command finished (8 sec)
> I guess it should not run "/bin/sh" on a binary.
The problem above seems to be Ubuntu related, it works ok on Fedora:
hough.cpp:111:10: warning: variable 'totsize' set but not
used [-Wunused-but-set-variable]
Installing...
Updating metadata file...
Installation of <r.houghtransform> successfully finished
(Fri Sep 7 13:49:58 2012) Command finished (8 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/854#comment:21>
