[GRASS-dev] v.buffer doesn't respect region?
Eric Momsen eric.momsen at gmail.com
Fri Sep 7 08:00:42 PDT 2012
> The short answer is yes, it will be difficult. The GRASS-internal
> vector buffering algorithm has a number of bugs, the only vector
> buffering method that is AFAICT bug-free is v.buffer in trunk with
> GEOS support which uses the GEOS buffering algorithm which in turn
> does not (yet?) support geodesic distances in latlong.
> Markus M
I was just using v.buffer yesterday, and found it was ignoring my region
settings, it processed the entire map instead of a small area.
I updated GRASS yesterday, and am compiled with GEOS.  Am I missing
something else, should v.buffer respect the region?
-Eric
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120907/fc14fa6f/attachment.html>
