[GRASS-dev] [GRASS GIS] #1696: Error message v.db.dropcol (Add-On Path)
GRASS GIS trac at osgeo.org
Sun Sep 9 03:19:23 PDT 2012
 Reporter:  jradinger      |       Owner:  hamish
     Type:  defect         |      Status:  assigned
 Priority:  blocker        |   Milestone:  6.4.3
Component:  Shell Scripts  |     Version:  unspecified
 Keywords:                 |    Platform:  Unspecified
      Cpu:  All            |
Changes (by hamish):
  * priority:  normal => blocker
Comment:
 Replying to [comment:1 hamish]:
 > right, this is a sibling of #1683, sorry I haven't been able to
 > get to all of them yet. Further review of the GUI's method of
 > setting the ADDON environment variable is needed too, but the
 > scripts should be robust enough to deal with it regardless.
 re. "Further review of the GUI's method of setting the ADDON environment
 variable is needed", 6.4.3 should not be released with the recent system
 vs. grass enviro var duplication confusion.
 Last chance to justify the need for a parallel method before I remove the
 g.gisenv ADDON_PATH stuff from init.sh and the GUI in 6.x.svn... As quoted
 above, I didn't want to do that without discussion of why the redundant
 g.gisenv method needed to be there.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1696#comment:2>
