[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
trac at osgeo.org
Mon Sep 10 01:55:34 PDT 2012
Reporter: antonioall | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Keywords: v.in.lines | Platform: MSWindows 7
Cpu: x86-64 |
Hello,
The file Coordinate.txt is:
496174.445494,4553975.166661,429.9415
495577.433542,4556363.214470,372.9797
NaN,NaN,NaN
497882.563024,4554290.256303,370.0215
NaN,NaN,NaN
NaN,NaN,NaN
497899.146689,4556479.300127,382.7335
NaN,NaN,NaN
NaN,NaN,NaN
The Text of Error is:
(Mon Sep 10 10:44:48 2012)
v.in.lines -z input=C:\myPATH\Coordinate.txt output=prova fs=,
C:/GRASS GIS 6.4.3svn/scripts/v.in.lines: line 108:
/otherMyPath/PERMANENT/.tmp/4520.0: No such file or
directory
head: cannot open `/otherMyPath/PERMANENT/.tmp/4520.0' for reading: No
such file or directory
ERROR: Not enough data columns. (incorrect fs setting?)
(Mon Sep 10 10:44:48 2012) Comando terminato (0 sec)
Thanks,
Best regards
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727>
