[GRASS-dev] [GRASS GIS] #1719: GRASS 7 Monitor command line support
GRASS GIS trac at osgeo.org
Mon Sep 10 03:10:14 PDT 2012
 Reporter:  annalisapg   |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  d.mon        |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by wenzeslaus):
 Replying to [comment:16 glynn]:
 > In theory, the fastest solution should be to use the cairo driver with
 output to X Pixmaps. The d.* modules generate output in video memory, and
 may be hardware accelerated. Compositing occurs entirely in video memory,
 and may be hardware accelerated. The main unknowns are how hard wxWidgets
 makes this, and whether something similar can be achieved on other
 platforms.
 In wxWidgets there is wxBitmap ([http://wxpython.org/docs/api/wx.Bitmap-
 class.html wxPython], [http://docs.wxwidgets.org/2.8/wx_wxbitmap.html
 wxWidgets]).
 This class encapsulates the concept of a platform-dependent bitmap, either
 monochrome or colour or colour with alpha channel support.
 This wxBitmap can be directly drawn on some wx widget/window. This
 operation is fast.
 Can be wxBitmap used for what you are talking about? It is the same as X
 Pixmap on linux?
 But how would be this bitmap/pixmap transfered from d.* module to wxGUI
 application?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:17>
