[GRASS-dev] [GRASS GIS] #1633: Unable to display shapefile attribute table due to pipe characters in dbf field
trac at osgeo.org
Mon Sep 10 17:11:36 PDT 2012
field
Reporter: richardc | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.1
Resolution: fixed | Keywords: database, separator
Platform: Linux | Cpu: Unspecified
Description changed by hamish:
Old description:
> Hi,
> I'm receiving the following error on attempting to view the attribute
> table of shapefiles in GRASS 6.4.1.2 (on Ubuntu Lucid):
> item = layer, log = self.goutput)
> File "/usr/lib/grass64/etc/wxpython/gui_modules/dbm.py",
> line 653, in __init__
> self.__createBrowsePage()
> line 698, in __createBrowsePage
> self.mapDBInfo, layer)
> line 95, in __init__
> keyColumn = self.LoadData(layer)
> line 247, in LoadData
> self.AddDataRow(i, record, columns, keyId)
> line 286, in AddDataRow
> if self.columns[columns[j]]['ctype'] != types.StringType:
> IndexError
> list index out of range
> '''Method:'''
> I import the shapefile as follows:
> Layer Manager > File > Import vector data > Common import formats >
> Select ESRI shapefile > Browse and select file > Import
> And then select the layer in 'Layer Manager', and click on the 'Show
> attribute table' icon. Then the error results
> 'Please wait loading attribute data..' with the following in the command
> console -
> IndexError
> On closer inspection of the dbf file, some of the fields contain pipe
> (i.e., '|') characters. On removing these the attribute table can be
> displayed.
> QGIS is able to display all data in the attribute table, including 'pipe'
> characters.
> Example of problem fields in single column named 'VARNAME_1,C,150':
> VARNAME_1,C,150
> Bangkok|Krung Thep|Krung Thep Maha Nakhon|Phra Nakhon-Thonburi
> Buri Rum
> Chaxerngsao|Pad Rew|Paed Riu|Petrieu|Shajeun Dhrao
> Chainat
> Chantaburi|Muang Chan
> NOTE: issue posted originally at http://osgeo-org.1560.n6.nabble.com
> /Index-error-Unable-to-show-attribute-table-of-shapefile-
> tp4678952p4678952.html
New description:
IndexError
'''Method:'''
Layer Manager > File > Import vector data > Common import formats > Select
console -
IndexError
displayed.
characters.
VARNAME_1,C,150
Buri Rum
Chainat
Ticket URL: <http://trac.osgeo.org/grass/ticket/1633#comment:5>
