[GRASS-dev] GRASS6.4.3svn d.rast -o, d.vect -c, clarification
Helena Mitasova
hmitaso at ncsu.edu
Mon Sep 10 19:26:26 PDT 2012
Anna,
here is a more complete information:
this is what I typed in and running it resulted in the error message below
d.vect -c basin_50Kval
if you try to rerun it by retrieving it from history using up arrow it shows this (apparently that is what I sent without checking it)
d.vect map=-c basin_50Kval
it works with the word map
d.vect -c map=basin_50Kval
or if -c is at the end
d.vect map=basin_50Kval -c
so it unfortunately does the same thing as d.rast,
Helena
On Sep 10, 2012, at 3:17 AM, Anna Kratochvílová wrote:
> On Mon, Sep 10, 2012 at 3:09 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
>>>> d.rast -o landuse96_28m cat=1,2
>>>> run in command console is interpreted as follows:
>>>> Command 'd.rast -l -a -n -d -u -s -e -9 -6 -_ -2 -8 -m
>>>> map=-o cat=1,2' failed
>>>> Details: Sorry, <l> is not a valid flag
>>>> Sorry, <a> is not a valid flag
>>>> Sorry, <n> is not a valid flag
>>>> Sorry, <d> is not a valid flag
>>>> Sorry, <u> is not a valid flag
>>>> Sorry, <s> is not a valid flag
>>>> Sorry, <e> is not a valid flag
>>>> Sorry, <9> is not a valid flag
>>>> Sorry, <6> is not a valid flag
>>>> Sorry, <_> is not a valid flag
>>>> Sorry, <2> is not a valid flag
>>>> Sorry, <8> is not a valid flag
>>>> Sorry, <m> is not a valid flag
>>>> d.rast landuse96_28m cat=1,2 -o works fine.
>>> I tried to fix it so it should work now. I hope I didn't break
>>> something else, this is quite difficult to test.
>> does this fix solve also the flags with d.vect? For example I get
> This should probably be d.vect -c map=basin_50Kval? This case works.
> "d.vect map=-c basin_50Kval" is bad input and it would be difficult to
> handle all wrong inputs.
>>> Command 'd.vect -b -a -s -i -n -_ -5 -0 -K -v -a -l map=-c'
>>> failed
>>> Details: Sorry, <b> is not a valid flag
>>> Sorry, <5> is not a valid flag
>>> Sorry, <0> is not a valid flag
>>> Sorry, <K> is not a valid flag
>> Thanks a lot.
>> I think I have written that the color fill on cutting planes does not work on windows - I tried it again and it works great,
>> We just worked in class with wxnviz last week and we did not have any problems on 20+ computers and laptops
>> running windows and Mac OSX, so that is fantastic, given how new the GUI is.
> I'm glad to hear that.
>> Also, this is the first year that I haven't seen many complaints about import/export of raster and vector data,
>> so that is a great improvement too.
>> The only comment I have seen so far was lack of Browse button when selecting the directory for v.out.ogr output,
>> I am wondering whether it is intentional due to some technical issues or just an oversight,
>> given that r.out.gdal has such option.
> I don't know, the gui respects that the dsn option is string and not
> file. There is probably some difference but someone would know this
> better.
> Anna
>> Helena
>>>> add volume still does not open dialog
>>> Maybe someone else (who is more familiar with PATH and Makefiles) could help?
>>> Anna
>>>> I am running Michaels Mac binary,
>>>> Helena
>>>> Helena Mitasova
>>>> Associate Professor
>>>> Department of Marine, Earth, and Atmospheric Sciences
>>>> 2800 Faucette Drive, Rm. 1125 Jordan Hall
>>>> North Carolina State University
>>>> Raleigh, NC 27695-8208
>>>> hmitaso at ncsu.edu
>>>> "All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
