[GRASS-dev] Addons to Parallelize
Fernando Sierra fernando.sierra at ciemat.es
Thu Sep 13 00:18:39 PDT 2012
Hi All,
my name is Fernando Sierra, I'm working with Grass7 and I want to
parallelize a few commands.
I have a ToDoList:
Priority Order:
r.prominence
r.cva.
r.walk
r.cost
r.mapcalc
r.surf.rst
r.param.scale
LIDAR
v.outlier
v.lidar.edgedection
v.lidar.growing
v.lidar.correction
Secondary:
r.drain
r.recode
r.los
r.topidx
r.regression.line
r.stats.
Satellite
i.fft
i.pca
i.cca
i.ifft
i.rgb.his
i.spectral
i.zc
I don't know which commands are parallelized or could be parallelized.
Do you have any idea or suggestion about how to start?
Thanks for your help!
Regards,
/Fernando Sierra Pajuelo
*System Administrator / Researcher*
/c/ Sola nº 1; 10200 TRUJILLO, SPAIN/
/Tel: +34 927 65 93 17 Fax: +34 927 32 32 37/
CETA-Ciemat logo <http://www.ceta-ciemat.es/>
Confidencialidad:
Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su destinatario y puede contener información privilegiada o confidencial. Si no es vd. el destinatario indicado, queda notificado de que la utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente respondiendo al mensaje y proceda a su destrucción.
Disclaimer:
This message and its attached files is intended exclusively for its recipients and may contain confidential information. If you received this e-mail in error you are hereby notified that any dissemination, copy or disclosure of this communication is strictly prohibited and may be unlawful. In this case, please notify us by a reply and delete this email and its contents immediately.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120913/3d30710a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120913/3d30710a/attachment-0001.png>
