[GRASS-dev] [GRASS GIS] #1730: GRASS 6.4.2 libgdal (GDAL 1.9.1) Disconnect
trac at osgeo.org
Fri Sep 14 14:51:20 PDT 2012
Reporter: osgeodls | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: 6.4.2
Keywords: | Platform: Unspecified
Cpu: Unspecified |
When trying to run GRASS 6.4.2 under Linux (Ubuntu 10.04 LTS) I get the
following error message to the console on startup:
/usr/local/lib/libgdal.so.1: no version information available (required
by /usr/lib/grass64/lib/libgrass_vect.6.4.2.so)
Is there a procedure 'fix' for this ? I downloaded gdal and compiled it
to get rid of a prior error message from 'ogr2ogr' about a version
mismatch but now when I launch gis.m I get: "g.proj or projection error:
g.proj /usr/local/lib/libgdal.so.1: no version information available
(required by g.proj) - g.proj: /usr/local/lib/libgdal.so.1: no version
information available (required by
/usr/lib/grass64/libgrass_gproj.6.4.2.so) Can I assume this is a GRASS-
only problem, as QGIS (1.9.0) seems fine with use of the PROJ library, as
is ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1730>
