[GRASS-dev] [GRASS GIS] #1734: support lat long rasters with half pixel overlap outside -180W, 90N, 180E, 90S
GRASS GIS trac at osgeo.org
Tue Sep 18 05:08:39 PDT 2012
#1734: support lat long rasters with half pixel overlap outside -180W,90N,180E,90S
 Reporter:  karme        |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Default      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 Just wanted to import gmted2010 data having extent to the south of 90d 0'
 0.50"S. I don't see a clean fix. One workaround is the throw away one row,
 but then half a pixel is missing to 90S.
 (see also: http://grass.osgeo.org/wiki/Global_datasets describing the same
 problem with etopo1).
 Using grass 6.4.2 r.in.gdal does the wrong thing (TM). It assumes there is
 a rounding error and adjusts the south extent to -90S and displays the
 warning:
 "WARNING: Fixing subtle input data rounding error of south boundary
          (-0.000138889>1e-06)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1734>
