[GRASS-dev] Error and Warning in GUI
Anna Kratochvílová kratochanna at gmail.com
Tue Sep 18 06:45:01 PDT 2012
On Mon, Sep 17, 2012 at 4:26 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> in GRASS6.4.3 I noticed that an error message shows up in red with ERROR in the GIS manager output window
> while warning just shows the text in blue but the word WARNING is missing (it shows up when running this in shell)
It's good you noticed it, it was a typo [1], now it's working.
Anna
[1] http://trac.osgeo.org/grass/changeset/53204
> This is causing confusion - students do not know what the message means - is that a problem or can they ignore it?
> Would it be possible to add the word WARNING so that the message is consistent with the shell and with the
> ERROR message.
> here is an example of what I am talking about:
> r.average base=zipcodes cover=elevation out=elev_avgzip
> ERROR: option <output>: <elev_avgzip> exists.
> r.average base=zipcodes cover=elevation out=elev_avgzip2
> r.stats:
> Cats for raster map <elevation at PERMANENT> are either missing or have no explicit labels. Using nsteps=255.
> r.recode:
> r.recode complete. Raster map <elev_avgzip2> created.
> Thank you, Helena
> Helena Mitasova
> Associate Professor
> Department of Marine, Earth, and Atmospheric Sciences
> 2800 Faucette Drive, Rm. 1125 Jordan Hall
> North Carolina State University
> Raleigh, NC 27695-8208
> hmitaso at ncsu.edu
> "All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
> On Aug 28, 2012, at 11:28 AM, Markus Neteler wrote:
>> On Fri, Aug 24, 2012 at 10:53 AM, Peter Löwe <ploewe at gfz-potsdam.de> wrote:
>>> Maybe this would be a good place to collect such kind of info:
>>> http://grass.osgeo.org/wiki/GRASS_GIS_Performance
>>> FWIW I included a section on the limitation concerning "vectors with LOTS of
>>> attributes". I just ran into that concrete wall the other day.
>> For the record, I have updated
>> http://grass.osgeo.org/wiki/GRASS_GIS_Performance#Maximum_Number_of_Attribute_Columns
>> Note that it is a DB backend limit which subsequently constraints GRASS GIS. You
>> can use a recompiled SQLite backend to manage *many* columns (see link in
>> Wiki page above).
>> best,
>> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
