[GRASS-dev] Grass SVN in Android, display issue
Glynn Clements
glynn at gclements.plus.com
Thu Sep 20 00:08:08 PDT 2012
Markus Neteler wrote:
> /home/neteler/grass70/dist.arm-unknown-linux-androideabi/bin/g.mkfontcap
> -s > /home/neteler/grass70/dist.arm-unknown-linux-androideabi/etc/fontcap
> /bin/sh: /home/neteler/grass70/dist.arm-unknown-linux-androideabi/bin/g.mkfontcap:
> cannot execute binary file
This should be fixed by r53237.
You'll need to run g.mkfontcap on the target system to build the
fontcap file. But ideally that should be done even when not
cross-compiling; in general, there's no reason to assume that the
target system has the same fonts as the build system.
