[GRASS-dev] [GRASS GIS] #1745: proposal: make -a flag the default behaviour for g.region
trac at osgeo.org
Wed Sep 26 04:43:49 PDT 2012
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
In my experience, when working with raster, having a precise resolution is
the most important issue, while exact extension is less important. I often
use existing vector data or bounds coordinates to determine the extent,
but then have to use the -a flag to make sure that the desired resolution
is kept.
I would like to propose that in grass7, the behaviour is switched, i.e. to
make the -a flag (Align region to resolution) the default behaviour, and
"align to bounds" the option.
I know this is a fundamental change in a fundamental module, but it's been
itching for quite a while and I always find myself in difficulties having
to explain to students why GRASS' default behaviour is the way it is...
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1745>
