[GRASS-dev] [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
GRASS GIS trac at osgeo.org
Thu Sep 27 02:35:36 PDT 2012
 Reporter:  hamish                   |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  critical                 |   Milestone:  6.4.3
Component:  Projections/Datums       |     Version:  svn-releasebranch64
 Keywords:  location wizard, g.proj  |    Platform:  All
      Cpu:  All                      |
Comment(by mlennert):
 Replying to [comment:18 neteler]:
 > Replying to [comment:17 cmbarton]:
 > > This is still broken and is producing incorrect projections.
 > This statement is a bit generic :) I can successfully reproject data
 > for the projections in use here.
 In comment:15 you say that you are using proj-4.7.0-5.fc17.x86_64. The
 problem appears with 4.7.1, no ?
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1452#comment:21>
