[GRASS-dev] [GRASS GIS] #1747: v.rast.stats on dbf shapefile not enough precision even with DOUBLE PRECISION
trac at osgeo.org
Fri Sep 28 10:26:17 PDT 2012
PRECISION
Reporter: vesnikos | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: | Platform: Linux
Cpu: x86-32 |
When I'm doing v.rast.stats with grass (v6.4.2) and a polygon with a dbf
db, the results come back for each row with two decimental numbers. The
column attribute is of type "DOUBLE PRECISION" . That presicion is not
enough.
for grass7 the v.rast.stats come back with much better presicion(<6
decimental digits)
http://i49.tinypic.com/2iqohmu.png
Ticket URL: <http://trac.osgeo.org/grass/ticket/1747>
