[GRASS-dev] Grass SVN in Android, display issue
Sören Gebbert
soerengebbert at googlemail.com
Fri Sep 28 15:39:01 PDT 2012
2012/9/24 Glynn Clements <glynn at gclements.plus.com>:
> Sören Gebbert wrote:
>> >> i have tested the raster3d library and most of the related modules intensively.
>> >> I rediscovered an ugly bug in the 3D raster run length encoding (RLE)
>> >> compression implementation and modified the library test to catch it.
>> >> I am unable to fix the RLE compression bug.
>> > Can you elaborate on this RLE bug?
>> As far as i understand the RLE encoding/decoding algorithm in
>> lib/raster3d/rle.c is buggy.
>> The functions rle_length2code() and rle_code2length implement wrong
>> length computation for strings larger than 129031 characters.
>> I have put some comments in the code.
> Right. Clearly that case hasn't happened in practice, because it would
> result in fairly obvious errors.
>> The length computation:
>> length = 254 ^ c + 254 * b + a; b, a < 254
>> works only for c <= 2. For c == 3 the implementation should be:
>> length = 254 ^ 3 + 254 ^ 2 * c + 254 * b + a; c, b, a < 254
> Indeed. Clearly, there's no way that all values up to 254^3 can be
> represented with only two "value" bytes.
> The ideal solution would be to store runs of >= 254^2 as multiple
> runs. That would maintain backward compatibility while avoiding the
> bug. But that would require re-writing Rast3d_rle_encode() and
> Rast3d_rle_count_only(); there's no way that G_rle_codeLength and
> rle_length2code can be fixed, as they assume that any length can be
> encoded.
So this bug is not fixable at all?
>> However, i do not understand the advantage of having RLE first and a
>> LZ77 or LZ78 compression afterwards.
>> Shouldn't be the LZ77/78 compression sufficient for compression of
>> float/double values?
> For sparse data, using RLE first can often provide a noticeable
> improvement.
I would prefer to disable RLE and keep the code only for backward compatibility.
>> Oh well, i did not know that the G_lzw_* functions don't exist.
>> Its a bit confusing that the option that switches on the LZ77
>> compression is called RASTER3D_USE_LZW ... .
> RASTER3D_USE_LZW switches on "real" compression (either LZW or LZ77,
> depending upon the USE_LZW_COMPRESSION macro).
> When LZW was replaced by LZ77, presumably the RASTER3D_USE_LZW name
> was kept in order to avoid changing the external API.
> Given how long it has been since LZW was supported, and that LZW and
> LZ77 are mutually exclusive at compile time, there seems little point
> in keeping any of the LZW code.
I will try to remove the LZW compression code from the raster3d lib so
that full backward compatibility is assured.
Best regards
Soeren
