[GRASS-dev] [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
trac at osgeo.org
Fri Sep 28 15:53:18 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: location wizard, g.proj | Platform: All
Cpu: All |
Comment(by cmbarton):
Replying to [comment:20 neteler]:
> For example, the Italian EPSG code 3003 works nicely, see attached
> screenshot.
OK. I did a couple tests and see better where my problem lies.
Datum transforms DO work OK for EPSG codes but do NOT work for selecting
the same parameters from a list. For example, if you select ED50, UTM Zone
29 from the EPSG list (23029) you get a datum transform list. But if you
pick UTM, Zone 29, ED50 from the list of projections and datums you do NOT
get a list of datum transforms.
Is this the same bug or a different one?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1452#comment:23>
