[GRASS-dev] [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
GRASS GIS trac at osgeo.org
Sat Sep 29 16:52:03 PDT 2012
 Reporter:  hamish                   |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  critical                 |   Milestone:  6.4.3
Component:  Projections/Datums       |     Version:  svn-releasebranch64
 Keywords:  location wizard, g.proj  |    Platform:  All
      Cpu:  All                      |
Comment(by cmbarton):
 In fact eur50 is not recognized. Same is true for at least several other
 datums. Since they are not recognized, they do now spawn datum transforms.
 For example, wgs84 is recognized by g.proj
 GRASS 7.0.svn (newLocation):~ > g.proj -d proj4='+proj=utm +datum=wgs84'
 GRASS datum code: wgs84
 WKT Name: WGS_1984
 Datum transformation parameters (PROJ.4 format):
         towgs84=0,0,0,0,0,0,0
 but European Datum 1995 (eur50) is not recognized.
 GRASS 7.0.svn (newLocation):~ > g.proj -d proj4='+proj=utm +datum=eur50'
 WARNING: Datum <unknown> not recognised by GRASS and no parameters found
 Datum name not present
 Datum parameters not present
 All unrecognized datums that I tested are listed in
 ../etc/proj/datums.table
 Could this be a problem more with g.proj than with proj4?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1452#comment:27>
