[GRASS-dev] off_t question
Martin Landa
landa.martin at gmail.com
Mon Apr 1 09:40:03 PDT 2013
2013/4/1 Martin Landa <landa.martin at gmail.com>
> gcc -E sizes.c -D_FILE_OFFSET_BITS=64 | grep off_t
> typedef __off64_t off_t;
the reason is that __off64_t is defined on my machine (shouldn't be
long long int?) also as
typedef long int __off64_t;
So PRI_OFF_T in gis.h should be probably fixed.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
