[GRASS-dev] off_t question
Glynn Clements
glynn at gclements.plus.com
Tue Apr 2 05:16:26 PDT 2013
Martin Landa wrote:
> > What should be fixed is this part in Grass.make:
> > # crude hack for vector LFS, LFS_FLAGS should be set by configure
> > ifdef USE_LARGEFILES
> > LFS_CFLAGS = -D_FILE_OFFSET_BITS=64
> > endif
> > _FILE_OFFSET_BITS shouldn't be set on a system with a 64-bit "long".
> > The main problem is that the LFS tests were taken wholesale from
> > cdrtools and no-one understands them.
> thanks for clarification, what kind of fix do you suggest?
I believe that the intended usage is to add the appropriate #undef
directives to config.h.in, which would either be converted to #define
directives or commented out.
I can't verify that this works for _FILE_OFFSET_BITS as I don't have
access to a 32-bit Linux system.
However, it works for _LARGEFILE_SOURCE, where the #undef (which is
inside a "#if 0") is normally commented out but converted to a #define
if -ansi as added to CFLAGS (which will disable fseeko/ftello by
default).
There are three distinct macros involved:
_LARGEFILE_SOURCE is used to enable fseeko() and ftello(). This is
enabled automatically if _XOPEN_SOURCE>=500 (defining _GNU_SOURCE sets
_XOPEN_SOURCE to 700; gcc defines _GNU_SOURCE if you don't use -ansi
or -std=).
_FILE_OFFSET_BITS is set to 64 to have glibc make off_t a 64-bit type,
even on 32-bit systems.
_LARGE_FILES is apparently an AIX-ism.
It appears that earlier versions of the macros would also try defining
_XOPEN_SOURCE and/or _XOPEN_SOURCE_EXTENDED to get the fseeko/ftello
declarations, but that isn't the case for the versions in our
aclocal.m4.
Having said all that, one problem with using config.h is that gis.h
includes it *after* stdio.h, while those macros need to be defined
before stdio.h is included.
> > On the plus side, the warnings don't indicate a real problem. They
> > arise because C considers "long int" and "long long int" to be
> > distinct types even when they have the same size and representation.
> Just note that diglib is using PRI_OFF_T for off_t formatting, in
> vector lib is used mostly %ld.
That will break on 32-bit systems with LFS enabled, as %ld will expect
a 32-bit value while an off_t will be a 64-bit value. As printf() etc
are variadic, the compiler doesn't know the correct argument types and
can't perform implicit conversions (the __attribute__((format,...)) is
only used for warnings; it won't result in conversions).
If the off_t is the final argument, it will just result in an
incorrect value (the bottom 32 bits will be used on little-endian
systems, the top 32 bits on big-endian systems).
If there are additional arguments after the off_t, everything will be
out of sync, i.e. the first 4 bytes of the off_t will be used for the
%ld, the last 4 bytes will be treated as the following argument (part
of it).
