[GRASS-dev] compilation of grass on AIX 7.1
Markus Neteler
neteler at osgeo.org
Wed Apr 3 01:46:19 PDT 2013
On Wed, Apr 3, 2013 at 10:06 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> off_t would be a good start.
/usr/include/sys/types.h
#ifndef _FPOS_T
#define _FPOS_T
#ifdef _LARGE_FILES
typedef long long fpos_t;
#else
typedef long fpos_t;
#endif /* _LARGE_FILES */
#ifdef _LARGE_FILE_API
typedef long long fpos64_t;
#endif /* _LARGE_FILE_API */
#endif /* _FPOS_T */
#ifndef _OFF_T
#define _OFF_T
#ifdef _LARGE_FILES
typedef long long off_t; /* 64 bit file offset */
#else
typedef long off_t; /* file offset (32/64) */
#endif /* _OFF_T */
typedef long long off64_t;
#endif
Offlist (due to copyright constraints) I may also send the entire
file.
> One thing which can help is to create an empty .c file then use e.g.:
> gcc -ansi -E -dM empty.c | sort > macros.h
> This will generate a list of the macros which are predefined by gcc.
Attached as aix53_macros.h.
Markus
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130403/f40c5117/attachment-0001.bin>
