[GRASS-dev] [GRASS GIS] #1912: g.mapset warns of illegal filename in mapset= but creates the mapset anyway.
trac at osgeo.org
Wed Apr 3 09:46:17 PDT 2013
anyway.
Reporter: torsti | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:1 torsti]:
> Looking at the source it seems the issue is that neither
'''general/g.mapset/main.c''' nor '''lib/gis/make_mapset.c''' include a
call to ''G_legal_name()'' and the mapset dir itself is created with
''G_mkdir()'' which is just a thin wrapper around ''mkdir()''.
> So probably '''make_mapset.c''' is what should be patched.
The warning is printed by the parsers (which calls `G_find_file()`), I
disabled this check (file overwrite) for 'mapset' element in r55612. In
r55608 I added to `G_make_mapset()` check for name legality. Done only in
GRASS 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1912#comment:2>
