[GRASS-dev] compilation of grass on AIX 7.1
Markus Neteler
neteler at osgeo.org
Wed Apr 3 15:40:40 PDT 2013
On Wed, Apr 3, 2013 at 7:57 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> > This doesn't fit with the off_t-related errors you were getting in
>> > defs/gis.h.
>> Now I got it... gcc picks stuff up from /opt/freeware/bla. Sorry for
>> the confusion.
> In which case, you need to look at that version of sys/types.h to
> figure out why off_t isn't getting seen.
I found the path with
/opt/freeware/bin/gcc -print-search-dirs
Hence ("randomly" citing):
cat /opt/freeware/lib/gcc/powerpc-ibm-aix5.3.0.0/4.2.0/include/sys/types.h
#ifndef _H_STANDARDS
#include <standards.h>
#endif
#include <strict_stdtypes.h>
#ifndef _H_INTTYPES_TYPE_TS
#include <sys/inttypes.h>
#endif
* The ANSI and POSIX standards require that certain values be in types.h.
* It also requires that if _ANSI_C_SOURCE or _POSIX_SOURCE is defined
* then ONLY those values are present. This header includes all the ANSI
* and POSIX required entries.
* Other entries are included in _ALL_SOURCE.
#ifdef _ANSI_C_SOURCE
#ifdef _LARGE_FILES
typedef long long fpos_t;
#else
typedef long fpos_t;
#endif /* _LARGE_FILES */
#ifdef _LARGE_FILE_API
typedef long long fpos64_t;
#endif /* _LARGE_FILE_API */
#endif /* _ANSI_C_SOURCE */
#ifdef _POSIX_SOURCE
typedef int soff_t; /* Unambiguous 32 bit file offset */
#ifndef _OFF_T
#define _OFF_T
#ifdef _LARGE_FILES
typedef long long off_t; /* 64 bit file offset */
#else
typedef long off_t; /* file offset (32/64) */
#endif /* _OFF_T */
typedef long long off64_t;
#endif
(I can send the file offlist if useful).
FWIW:
http://forums.fedoraforum.org/showthread.php?t=266114
-> the test program there delivered "success".
Markus
