[GRASS-dev] [GRASS GIS] #1918: Missing $(RASTERLIB) $(RASTERDEP) in vector/v.in.region/Makefile
GRASS GIS trac at osgeo.org
Fri Apr 5 05:45:24 PDT 2013
 Reporter:  torsti       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 r55629 #include <raster.h> was added to main.c in v.in.region and it now
 uses symbols declared in raster.h there but wasn't an update to the
 Makefile, so for me compilation fails with a linker error:
 make
 : && gcc -L/home/torsti/Lataukset/Kehitys/grass_trunk/dist.x86_64-unknown-
 linux-gnu/lib -L/home/torsti/Lataukset/Kehitys/grass_trunk/dist.x86_64
 -unknown-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-
 link,/home/torsti/Lataukset/Kehitys/grass_trunk/dist.x86_64-unknown-linux-
 gnu/lib  -o /home/torsti/Lataukset/Kehitys/grass_trunk/dist.x86_64
 -unknown-linux-gnu/bin/v.in.region OBJ.x86_64-unknown-linux-gnu/main.o
 -lgrass_vector.7.0.svn -lgrass_gis.7.0.svn  -lm
 /usr/bin/ld: OBJ.x86_64-unknown-linux-gnu/main.o: undefined reference to
 symbol 'Rast_row_to_northing'
 /usr/bin/ld: note: 'Rast_row_to_northing' is defined in DSO
 gnu/lib/libgrass_raster.7.0.svn.so so try adding it to the linker command
 line
 gnu/lib/libgrass_raster.7.0.svn.so: could not read symbols: Invalid
 operation
 collect2: error: ld returned 1 exit status
 make: *** [/home/torsti/Lataukset/Kehitys/grass_trunk/dist.x86_64-unknown-
 linux-gnu/bin/v.in.region] Virhe 1
 I guess it should be something like this:
 Index: vector/v.in.region/Makefile
 --- vector/v.in.region/Makefile (revision 55638)
 +++ vector/v.in.region/Makefile (working copy)
 @@ -5,9 +5,9 @@
  include $(MODULE_TOPDIR)/include/Make/Module.make
 -DEPENDENCIES = $(VECTORDEP) $(GISDEP)
 +DEPENDENCIES = $(VECTORDEP) $(RASTERDEP) $(GISDEP)
 -LIBES = $(VECTORLIB) $(GISLIB)
 +LIBES = $(VECTORLIB) $(RASTERLIB) $(GISLIB)
  EXTRA_INC = $(VECT_INC)
  EXTRA_CFLAGS = $(VECT_CFLAGS)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1918>
