[GRASS-dev] [GRASS GIS] #666: add a scripting console
GRASS GIS trac at osgeo.org
Sat Apr 6 05:33:06 PDT 2013
  Reporter:  timmie       |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  svn-releasebranch64
Resolution:  fixed        |    Keywords:  python
  Platform:  All          |         Cpu:  x86-32
Comment(by epifanio):
 Annakrat that is correct, those examples are for embedding the IPython
 *kernel*, not UI.
 IMHO,  try to embed the notebbok is worth to try (much powerful and easier
 to implement than the standard IPython shell)
 in wx 2.9 a simple code like :
 import wx
 import wx.html2
 app = wx.App(False)
 frame = wx.Frame(None, -1, 'A Simple Frame')
 browser = wx.html2.WebView.New(frame)
 browser.LoadURL("http://IP:PORT/NoetebookName.ipynb")
 frame.Show()
 app.MainLoop()
 will open a wx frame within the notebbok.
 # the problem here is wx2.9 ...
 We can have a "notebook dashboard" written in a WX frame as part of the
 grass wx gui, something like :
 #!/usr/local/bin/python
 import sys
 import wx
 import wx.html2
 class MyFrame(wx.Frame):
     def __init__(self, parent, title):
         wx.Frame.__init__(self, parent, -1, title,
                           pos=(150, 150), size=(350, 285))
         menuBar = wx.MenuBar()
         menu = wx.Menu()
         menu.Append(wx.ID_EXIT, "E&xit\tAlt-X", "Exit")
         menuBar.Append(menu, "&File")
         self.SetMenuBar(menuBar)
         self.CreateStatusBar()
         panel = wx.Panel(self)
         text = wx.StaticText(panel, -1, "Notebook Browser")
         text.SetFont(wx.Font(14, wx.SWISS, wx.NORMAL, wx.BOLD))
         text.SetSize(text.GetBestSize())
         NoetebookName_btn = wx.Button(panel, -1, "NoetebookName")
         self.Bind(wx.EVT_BUTTON, self.showBrowser, NoetebookName_btn)
         sizer = wx.BoxSizer(wx.VERTICAL)
         for ctrl in [text, browser_btn]:
             sizer.Add(ctrl, 0, wx.ALL, 10)
         panel.SetSizer(sizer)
         panel.Layout()
     def showBrowser(self, evt):
         app = wx.App(False)
         frame.Show()
 class MyApp(wx.App):
     def OnInit(self):
         frame = MyFrame(None, "Simple wxPython App")
         self.SetTopWindow(frame)
         frame.Show(True)
         return True
 if __name__ == '__main__':
     app = MyApp(redirect=False, clearSigInt=False)
     app.MainLoop()
 Instead of a single button, we'll have (auto generated) buttons for each
 notebook avalable in the IPython notebook dir, and open a new tab in the
 wx-dashboard-frame when a button is pressed
 (notebook dir is in the ipython_notebook_config.py
 "c.FileNotebookManager.notebook_dir")
 Hope make sense ...
 if looking for an "ancient" wx-gui for ipython .. i found something here
 [https://code.google.com/p/editra-plugins/wiki/IPythonShellPlugin here]
 but is really old ...
Ticket URL: <https://trac.osgeo.org/grass/ticket/666#comment:14>
