[GRASS-dev] libgis: G_FATAL_EXIT|PRINT|RETURN
Markus Metz
markus.metz.giswork at gmail.com
Sat Apr 6 14:00:04 PDT 2013
On Sat, Apr 6, 2013 at 6:27 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> libgis defines
> /* error codes */
> #define G_FATAL_EXIT 0
> #define G_FATAL_PRINT 1
> #define G_FATAL_RETURN 2
> These defines are used by a few functions, eg.
> G_check_input_output_name(). Other candidates could eg.
> Vect_open_old() and similar functions (eg. call G__error() when vector
> map is not found). I would suggest to add G__error() and
> G__set_error_code() just for internal use (see the attached path).
What's your motivation for adding G__error() and G__set_error_code()?
Are there problems with e.g. Vect_open_old()?
Markus M
> What do you think? Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
