[GRASS-dev] [GRASS GIS] #1723: G_OPT_DB_COLUMNS does not allow input of multiple column names
GRASS GIS trac at osgeo.org
Sun Apr 7 02:35:52 PDT 2013
 Reporter:  cmbarton          |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.3
Component:  wxGUI             |     Version:  unspecified
 Keywords:  multiple columns  |    Platform:  Unspecified
      Cpu:  Unspecified       |
Changes (by martinl):
 * cc: martinl (added)
  * keywords:  => multiple columns
  * component:  Default => wxGUI
Comment:
 Replying to [ticket:1723 cmbarton]:
 > G_OPT_DB_COLUMNS (gis.h) is supposed to indicate multiple column names
 can be entered into a field. But only single column names are actually
 accepted. Check out v.out.ascii for an example. I'm not sure WHERE the
 actual problem lies--in gis.h, in g.parser, in forms.py (no reference to
 G_OPT_COLUMNS in the latter however), or somewhere else.
 fixed in 'turek' in r55651.
 > Wherever this is defined for the interface, G_OPT_M_DATATYPE could
 probably be fixed too. It is supposed to bring up a list of GRASS
 datatypes, but does nothing AFAICT.
 This should be probably reported as separate ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1723#comment:1>
