[GRASS-dev] compilation of grass on AIX 7.1
Markus Neteler neteler at osgeo.org
Mon Apr 8 13:28:02 PDT 2013
On Mon, Apr 8, 2013 at 11:31 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> > A grep for "winsize" would be more useful. TIOCGWINSZ is being found,
>> > otherwise the code which uses "struct winsize" wouldn't be compiled
>> > and wouldn't generate an error.
>> Ok, found this in /usr/include/sys/ioctl.h:
>> struct winsize {
> But lib/gis/ls.c already includes <sys/ioctl.h>, provided that
> HAVE_SYS_IOCTL_H is defined.
> Is HAVE_SYS_IOCTL_H defined in config.h?
Yes:
/* define if sys/ioctl.h exists */
#define HAVE_SYS_IOCTL_H 1
> Is the struct winsize definition guarded by #if/#ifdef?
Yes:
#ifdef _ALL_SOURCE
/* Common ioctl's for all disciplines which are handled in ttiocom */
enum tty_ioctl {
union txname {                          /* used with TXGETCD */
 * window size structure used with TXSETWIN and TXGETWIN.  This is
 * exactly the same as the Berkeley structure and can be used with
 * TIOCSWINSZ and TIOCGWINSZ -- in fact they are defined to be the
 * same.
struct winsize {
        unsigned short  ws_row;                 /* rows, in characters */
        unsigned short  ws_col;                 /* columns, in characters */
        unsigned short  ws_xpixel;              /* horizontal size, pixels */
        unsigned short  ws_ypixel;              /* vertical size, pixels */
#endif /* _ALL_SOURCE */
So, I see only the #if/#ifdef which we want to avoid to use...
Markus
